Senior
here it is all assembled
here my lightened and balanced flywheel
i didn't realize that the weber carb i wanted to use is not a weber at all. i found out that the EPC 32/36 is not a weber but a knock-off of the weber
so i had to rummage through my parts shelf and i came up with this actual weber DGAV 32/36
now i have to rebuild this one so i can put it on the motor
