Results 1 to 5 of 5
Thread: a/t issues when cold
    New Bern, NC
    1986 Dodge D-50
    So my trans has been working good since I changed the fluid and adjusted the kickdown linkage. I've noticed when I first start the truck up when it's cold it doesn't wana go when you put it in gear. You've gota give it some gas. Once it gets moving it's good. Its just that first takeoff after startup. I've noticed this getting worse lately. I'm curious if there's anything I could do? Or could a trans flush do the trick? I know when i drained the fluid and changed the filter I only got about 4 quarts and the trans holds like 10?
    Low tranny fluid will cause that problem till it warms up. let the truck get up to operating temp then check the fluid with the engine running. you might be low and the pump is bleeding out when it sits and repriming on first start up. you might be 1-1.5L low.
    New Bern, NC
    1986 Dodge D-50
    Good call. I checked it when I got home and it was about 1/4" below the bottom mark of the "C" section so it's about 1-2 qts low. I'll get 2 qts of bulk ATF+4 from work tomorrow and add to it when I get home. Makes sense. The truck has always seemed sluggish and got poor MPG since I changed the trans fluid. Low fluid pressure or slippage could explain why. I just thought it was part of owning a power hogging automatic.
    oh man, fordbushi just saved your trany dood, lol. That new job must be distracting you or something from your normal train of thought.
    New Bern, NC
    1986 Dodge D-50
    Probably. I spent years at nissan doing all the diagnostic work and heavy line drivetrain work and now I'm primarily doing alignments, used cars and mitsubishis the rare site they are.
