Mr 4d55 supply
Can I ask why you would run them for 5 min??!! After 8 seconds you run the risk of melting and "Balloning". When u try to remove them they won't come easy and when they do the balloned tip will fall in the engine and force you to remove the head to get them out. 0 clearence between head and piston means instant knocking!
