Results 1 to 3 of 3
Thread: leaking!!!
    nj, nj
    1989 Dodge Power Ram 50
    leaking!!!
    so i got my frsh rebuild running but its leaking oil all over. i put a rubberized cork pan gasket on it and it seems to be leaking from it already. but it doesnt look like i can slide the pan out to seal it back up. anyone have a solution? and also the balace shaft side where the plate is seams to be leaking also. not sure if its cming from there or not. is there anything i could be missing that could be leaking? thanks
    So if you clean off the engine with water and let it run in the drive way, you should be able to see where it starts from. Use silicone on the pan, forget the gasket.
    nj, nj
    the pan wont drop down because of the diff. how do i squeeze it out? and also can u tell me how to set the kickdown cable?
