Results 1 to 6 of 6
Thread: escalade rims
    nh
    1991 Mitsubishi Mighty Max
    escalade rims
    Will escalade rims bolt right up to a 1991 mighty max
    Rockledge, PA
    No, the center needs to be bored out. The bolt pattern is correct
    As stated they do work on our trucks, but the center bore on the rims needs to be bored to about 3 3/4"-4" or have the rings/nubs grinded down on the hubs.
    Gray, Tn
    which one is safer grind the rims or hubs?
    Its a tossup - the amount removed from the wheel if done properly will not comprmise the wheel, the hubs on the front are easy, the rear axles would need to be turned down on a lathe to be done right. You will also need bulged lugnuts because the holes for the lugs are for 14mm studs and our studs are 12mm.
    I would say to turn down the hubs
