Results 1 to 7 of 7
Thread: rough vibration in gear
    New Bern, NC
    1986 Dodge D-50
    So i got my truck running again today. Runs great but has a bad vibration when you put it in drive. I know the balance shafts were timed right. The mounts looked good. Im gona inspect the trans mount next since i lifted it up and down alot. Anyone have other ideas? I marked and realigned the crank to flex plate and flex plate to t/c.
    New Bern, NC
    1986 Dodge D-50
    Well today i found a plate under my bench. This plate goes between the flex plate and crank. I think i found my problem.
    that spacer is needed to shim the torque convertor to the motor - hope it didn't damage anything.
    New Bern, NC
    1986 Dodge D-50
    I yanked the trans and put that plate back in. Made no real difference in the vibration. Everything on the trans works the way it was. I know the timing and balance shafts are right. Aside from changing mounts im kinda stumped now
    are you sure you got the torque convertor completely mated to the tranny? Ohter than that, it could be an imbalance of the torque convertor or a bent flexplate.
    New Bern, NC
    1986 Dodge D-50
    I never took the t/c out of the trans when I did the overhaul. I put a plate over it to hold it back while we moved the truck around. As for the flex plate it's possible but in neutral it's not noticable and when you hit a certain rpm it starts to go away so I dont think that's it. I layed it down flat and didn't move it during the overhaul. It was bolted to the engine during transit so I won't rule it out. I'm going to have to drain the trans fluid and change the filter before I go too much further. The t/c could be acting up due to ariation of the fluid since it's overfull (i bought it that way) I do notice that the vibration is worse when stopped holding the brake. And if I let off the brake the worst of it goes away. Also the 2-3 slippage could be a problem with the trans filter so I want to see if that helps any.
    New Bern, NC
    1986 Dodge D-50
    I ended up getting all the fluids taken care of and the kickdown linkage adjusted right now the trans shifts beutifully but still has that vibration only in drive with foot on the brake. Drives me nuts sometimes. It goes away as soon as you let of the brake.
