Results 1 to 25 of 29
Thread: Electric fuel pump wiring?
    Round Rock, TX
    No schematic really, just get a relay. Have the relay controlled by the wire for the electronic choke. And just pull power from the battery for it. That way when the key is on the relay engages and the pump is powered off the battery.
    Germantown, Maryland
    1986 Dodge Ram 50
    So do you not use an oil pressure switch with your set-up? I've never done a mod like this before so I'm trying to get an idea of what i need
