Originally Posted by
geezer101
The thermo switches operate ancillary stuff like the exhaust riser from the exhaust manifold to the air cleaner neck. If you cap off the lines or connections from the carb/inlet manifold that are directly hooked up to the thermo switch, it will eliminate vac leaks and the engine will still run fine.
