			Freshman
					ECU replacement
							88 Ram 50 2.6L mt, have tried everything but replace ECU to get consistent lower rpm, low torque performance. Rebuilt carb and distributor, new plugs, wires, TPS, O2 sensor, coil, checked for vacuum leaks, checked temp sensor. Still pings and bogs down sometimes usually in higher gears when asking engine for more power. I've got a "new" Cardone reman ECU. The Dodge shop manual doesn't spell out a replacement procedure. Is it simply unhook battery, replace ECU and re-hook battery? Does the "computer"  need time/miles to relearn the engine inputs/feedback? Please advise and thanks. Randall
							This is a plug and play kind of thing. You are thinking about the obd2 system that is far advanced compaired to ours.
You've checked everything like recheck proper spark plug gap, check for vac leaks, clean egr, fuel filter, etc? Since you have the ecu I guess give it a shot. Chime in if it doesn't fix your bog problem.
							keep us posted im sure between everyone here it will get taken care of...goodluck man
			Inactive
							I had a similar Bog problem, but mine was during acceleration, an gong up hills, I advanced the timing on the distributor a bit, and viola problem solved!
			Freshman
							Please help me understand which pin is to be grounded and how to ground. According to the Dodge service manual, the #10 pin goes to the ign.coil neg terminal (engine speed sensor), #2 pin is ground for sensor and #11 is ground. Also recommended timing is 7 deg BTDC plus or minus 2 deg. What do yo suggest, 7 or less? The harness plug for this ECU (in cab near glove box)
			Land Speed Record Holder
							Ok, first, hook up your timing light, look at the timing marks, use some white out correction fluid to highlight the markings on the cover and on the balancer if they're hard to see. as you rev the engine  you will see the marks move around.
Here's the Plug, thats the passenger side above the fender well.
remove the cap, use a jumper wire with alligator clips or whatever to a nice metal ground in the engine compartment.
When you look at the timing marks again with the light, and rev the motor, the marks should be steady, indicating the ground is good and the ECU is in the set timing mode.
loosen the distributor clamp bolt (12mm IIRC) rotate the distributor till you achieve the desired value.
Haynes Manual says :
2.0 - 2.4L 4 cylinder engines 3-7 degrees BTDC
2.6L 4 cylinder engines 1989 and earlier 3-7 Degrees BTDC
1990 and later 6-10 degrees BTDC
3.0 V-6 engines 3-7 degrees BTDC
* refer to the Vehicle Emissions control information label in the engine compartment: use the information there if it differs from that listed here.
Tighten the Distributor clamp bolt.
Re-check the timing is still the correct value.
Remove the jumper, replace the dust cap, take a test drive.
			Freshman
							Hey LSR Mike, I didn't find the pigtail you show on my 88 Ram 50 2.6L mt. I took a picture of the same area on my engine, but don't know how to insert without a url. Suffice it to say I'm still in the dark on how to let the "new" reman ECU learn if possible on this year and model. Appreciate your insights, still not sure if they apply to me. The under the hood label and the original Dodge Service manual neither mention this "Special Procedure", though I know sometimes everything is not covered in the first issue. Thanks again. still having the same problem with loosing power SOMETIMES, when going up a grade or trying to accel, usually in the higher gears. Maybe I need to start a new thread and list all thats been tried so far. Any suggestions will be welcome. Randall
			Inactive
							Wow, good step by step though.
