just remove the screw that contacts the jet valve instead of cutting the rocker arm - easier and no mess from cutting the tab off. Also, once you put the Weber on, the jet valves are useless, as the adaptor plate covers the air feed to the valves. I also agree that the best fix is a non jet valve head.
