Update- pulled both motor and tranny, then put tranny back in. The Starion uses a hydraulic clutch whereas the MM uses a cable, and there was no definitive answer as to if the tail shaft on the MM's KN145 would bolt to the Starion's KM132.
Both motors are now out and sitting side by side. Pulled the oil pans and swapped, switched the dipstick location, and cleaned up the engine bay. While the motor is out I'm considering a balance shaft elimination... If I go that route I'll machine the flywheel.
Anyone ever thought about swapping dashboards? They measure the same width, and mounting points aren't far off. If the Starion fit the MM it would allow for the stock Tac, boost Gauge as well as all the cruise control and rather than working out the wiring halfway between engine and dash, you'd just have to splice in a few odds and ends like dome lights and tail lights. Just a thought.
