This thread answered a burning question I've had. I'm glad to hear the tailhousing interchanges with the transfer case. But to throw another wrench in the works: it sounds like you have a 4D55, and the donor might be from a gas engine? It appears that the transmission don't have removable bellhousings. Are input shaft dimensions and bellhousing boltpattern the same between gasser transmissions and diesels?
