Results 1 to 5 of 5
Thread: Fitting Rims
    Kapaa,HI
    Fitting Rims
    hey guys, im thinking of installing the Konig Countersteer rim on my 2wd mighty max. does anyone know if it will fit without sticking out of the fenders?
    N*Y
    r they 6 lugs ???
    need more info - rim diameter, tire size, backspacing, and that the center hole is larger than 100 mm in diameter.
    Cali
    are they the type X? those are nice rims.. and they are 6 lug. IMHO 16x8 w/ some beefy rubber would look good on our trucks, although lots of ppl run them on TRD's tacomas and stuff. but we need more info on the rim specs
    Kapaa,HI
    Quote Originally Posted by ikeepzitclean View Post
    No. im thinking of getting the offroad set. I know it will fit the bolt pattern but im worried on the offset and backspacing.
    Diameter: 16"
    Width: 8"
    Bolt pattern (PCD): 6x139.7mm
    Offset: 0mm
    Backspacing: 4.5"
