Bachelors Degree
question about head bolts
So in my rebuild since I've got everything apart I was pondering head studs. I've noticed the 94 MM 2.4L head bolts and 98 Eclipse 2.0L Turbo have the same head bolt number so I can assume (since ARP doesnt list anything for mighty max) that I can buy a set for the 4g63 and they should work fine. Anyone run through this before?
I believe they do work and someone has put them on before, I think all they had to do was grind a little inside the valve cover so it would sit on down on the head all the way as the studs touched a spot or two..
