the spring will need a higher spring rate to compensate for the lift - I think stock is 400#, so a lifted spring would be 500# or better, and the spring would be taller. Rancho also sells a helper leaf that adds 2" of lift in the rear - check your main leaf to be sure it isn't cracked like mine were - they cracked front to back not side to side though, very weird.
