Results 1 to 8 of 8
Thread: 89 ram 50 hi idle problems
    amarillo
    i just bought an 89 ram 50 with a new timing belt cant get it to idle down stays idled way high almost like the throttle is open all the way any help would be great the wife needs this for work.thanks again, maybe set the throttle cable or something just cant figure this one out, my ram 100 custom does not have this problem.
    Double check all the timing marks. Make sure the cam is not advanced 1 tooth. Also make sure there is nothing holding the throttle open. The cable should have some slack. Last check for vacuum leek.
    Let us know what you find.
    amarillo
    think i figured it out young kid owned it, had the idle screw tighened all the way down adjusted timing and set idle looks good so far thanks for the help.
    Well that was fairly straight forward on the repair. Let us know if there is something else we can give you ideas on. It's our pleasure.
    Hagerstown, MD
    Why did the kid tighten down the idle screw? There must have been something else going on that the maxxed-out idle compensated for.
    Watch out for spreading the idle needle seat on that carburetor. You'll need a new throttle-body if he tightened the screw down real hard. If you can replace the needle, and it fixes, you're lucky. Symptom is uneven idle that absolutely will not adjust out.
    Visalia ca
    Is there a specific way to adjust idle screw
    Wind the idle air needle in until it seats, then turn it 1 1/2 to 1 3/4 turns out. Wind out the throttle stop and wind it back in until it is just resting on the linkage. Start it up and check ignition timing, then make your adjustments (hopefully nobody has messed with the SAS-1 and 2 screws)
    Visalia ca
    Thanks for the reply geezer 101 n yes more than happy to help out with a donation will try it out later today but ? Wats the sas 1 & 2 screw
