Results 1 to 2 of 2
Thread: rocker arms
    Vincennes, Indiana
    rocker arms
    So, after i put the rocker arms and everything back on i noticed that there was some play on a few of them that was not there before. How do i go about doing this. And i also neec to know the torque pattern and lbs for ar that holds them on. Sorry i dont knowthe correct terms. I dont really do mechanics stuff.
    You have to prime the lifters to make sure they are pumped up - look in the manual section for the proper way to prime them. If you rebuilt the motor or head, replace the lifters - they are cheap enough and will prevent problems down the road. The torque values and sequence will be there also.
