Results 26 to 50 of 72
Thread: Natedog's 6g72 Turbo Swap
  1. #26
    WA
    I'm guessing clearance issue with firewall.
  2. #27
    Hartselle AL
    1991 Mitsubishi Mighty Max
    6G72-T
    Yup, I mentioned it way back in my first post. If the engine were newer it would have the crank and cam sensor's but since its the first generation engine it has the CAS on the cam shaft. Little re-engineering should fix it on my part (hopefully). If I were to do it over I'd have went with the later model engine. Too late now!
  3. #28
    Hartselle AL
    6G72-T
  4. #29
    Hartselle AL
    6G72-T
    Full Mandrel bennt 3 inch exhaust. Stock Appearing.
  5. #30
    WA
    I had a custom exhaust pipe come out and go over the frame rail and exit straight down, in front of the right rear tire. Hassled too much times by the local inspectors every year. Smart move on the "stock appearing" from the get go.
  6. #31
    Hartselle AL
    6G72-T
    We don't have inspections here, can't tell you the last time I owned a car that would pass a an emissions test!
  7. #32
    Hartselle AL
    6G72-T
    Little update on the intake!
  8. #33
    Hartselle AL
    6G72-T
    Got it back home... hope to get back on it soon!
  9. #34
    Good lord that thing looks so sexy, I want to do this swap one day!! Keep the updates coming, love seeing pics of this thing.
    Josh
    09 BMW 335i E92 Twin turbo
  10. #35
    Hartselle AL
    6G72-T
    Thank you, hearing other people are interested keeps me going. It still has a lot to do, but its getting there.
  11. #36
    Hartselle AL
    6G72-T
    Parts are back from coating.
  12. #37
    Wow, looks good.
    Brad was talking about feet getting into parts-pictures. In this one, it appears to be a cat.
  13. #38
    Olympia/wa
    1990 Dodge Ram 50
    Wow this project is awesome! I love it!!!
  14. #39
    Hartselle AL
    6G72-T
  15. #40
    That is some trick plumbing for the turbo set up Nate! A bit of heat shielding on the wheel well and you're home and hosed. Can you post up a full engine bay pic for us to look at please?
  16. #41
    Hartselle AL
    6G72-T
    Thanks, I'll get some more pictures in the next few days. Trying to figure out the mounting and such for all the AC before I start wiring it!
  17. #42
    Jacksonville, FL
    G54B-T
    Keep it coming man....lookin good
  18. #43
    Oakland, CA
    Nothing like a murdered out engine bay.
  19. #44
    This thing is going to be soooo badass!! What all do you have left toi do?
    Josh
  20. #45
    Hartselle AL
    6G72-T
    There is lots of little things left to do, get all the AC plumbed / replaced. Adapt multiple lines for coolant, oil, etc. I've still got to get the fuel system swapped over to the car pump, and mod the lines to the fuel rail. As well as the heater hoses, which I plan to pull the heater core and modify it for how I want things. Did I mention, I haven't even started wiring...
  21. #46
    Hartselle AL
    6G72-T
  22. #47
    Wow, Nate things are rolling great. The tolerances between parts on your build are so tight looking in them photos. I am wondering whats going to rattle together when you lite that truck up the first time. That G72 looks so nice in that bay also. Perfect build for that truck. Nice to see you progressing along and keeping us all posted with this. Very impressive work... You can no longer go to the Autoparts store for those particular parts since you damn well made everything custom.
  23. #48
    Hartselle AL
    6G72-T
    Thank you, I can't take all the credit though, my fab guy is very good. I just give him an idea and am flexible with how it works out. I'm slowly making progress, just been a little short on cash so not much happening right now. Hoping to make some more progress in the next few weeks.
  24. #49
    Hartselle AL
    6G72-T
    Just wanted to let you guys know that I haven't forgotten about this project. I've just been covered up with other things. I am currently swapping the engine in my Mirage, and I lost my best friend about 2 months ago... I've been trying to sort through all his Mitsu stuff and help his wife with it. I'll get back to this one soon. Just more important things have taken over.
  25. #50
    NW mississippi yall
    Dodge V8
    Nate.. You OK?
    Errol
