Finally got all the little pieces I've needed to finish the engine.
Started it up on the test stand today. I was excited about starting it so I forgot to hook up the choke which is why it wouldn't start at first and didn't react very well to the throttle. Since we know it runs now, I need to figure out where to mount the alternator, then run it again with the radiator hooked up. All in all, a very good morning for me.
https://youtu.be/aDX5Hf3yD7A
