Results 1 to 4 of 4
Thread: New user needs 4D55 rebuild advise.
    Yakima, WA
    1987 Mitsubishi Montero
    4D55-T
    New to this forum, the other one I'm on has not been helpful at all. I have a 4D55T with 180 psi in cylinders 1 and 2, and 300 psi in cylinders 3 and 4. So, looks like I'm in need of a rebuild. I'm sure this question has been asked before, so if there is an existing thread that describes what I need, then please direct. From what I can tell, the Chinese re-build kits are not good, and there may be a shortage of parts necessary. If someone could please get me a parts list and sources, I would be eternally grateful. Thanks
    Well we do have some links to places that can help you get parts in the link section.
    http://www.mightyram50.net/vbulletin...4843#post14843
    Are you sure the valves aren't just tight of there is a head problem? But as far as a list of parts I don't think anyone has done that yet.
    Laporte, IN
    1989 Dodge Power Ram 50
    check your valve lash and do a leak down test. that will give you the info you need. may be a bad head gasket blowing between 1 and 2.
    Yakima, WA
    4D55-T
    Quote Originally Posted by wrngwae View Post
    I've got oil shooting out the dipstick from leakage into the crankcase too.
