Results 1 to 25 of 48
Thread: Eclipse DSM Dohc 4G63 / 4G63T swap information
    Since there is always a lot of questions(and I get a fair amount of PM's) on swapping a 4g63 into these trucks I figured I would make a sticky post with info on what is needed for the swap and what needs to be done/modded. I might be missing a few things but I'll edit them in later as need be.
    Engine and engine wiring harness/ecu:
    *DOHC 4g63/t from preferably a 90-92.5 Mitsubishi Eclipse/Eagle Talon, Plymouth Laser. 93+ 7 bolt engines can be used but are not usually desirable as they are prone to crank walk.
    *Complete engine wiring harness, ecu, and mpi relay from the same year range vehicle as the motor. When performing the swap you get rid of the trucks engine harness completely and slap the 4g63 one in its place. You will need to shorten and lengthen some wires since engine is now positioned different than it was in the car. You then need to give the ECU and MPI Relay power and also wire the mpi relay to your fuel pump to run it, etc. A wiring diagram with what needs to be done and info thread can be found HERE thanks to the 4g63 swap guru Jeremy at hotrodcoffeeshop.com. Be sure to join his forums and read up on builds to gain more knowledge.
    Transmission:
    *Narrow block pattern KM132 5 speed(older 4 speed KM132 will also work) manual transmission from 83-89 Mitsu Mighty Max/Dodge Ram50 trucks with the g63b 2.0. To assure you have the right tranny measure the center to center distance between the two lower bellhousing bolt holes and it should be around 12.5". wideblock trannies(which you dont want) measure around 13.25".
    *Bill Hichner on the projectzerog.com(Also a great source for info on 4g63 swaps) forums makes tons of bellhousing adapters for a bunch of different transmissions also. Anything from Toyota R154 to GM and Ford trannies if you want to go that route.
    Flywheel/clutch/pp for KM132 setup:
    *Front wheel drive flywheel and pressure plate from same year range vehicle as motor. You will want the center hole on the flywheel machined a little bigger to fit the trucks pilot bearing for added reliability.
    *Clutch disk from 87-89 2.0L truck. If you plan on making a lot of power then I suggest buying a custom made clutch disc and maybe converting to a hydraulic clutch.
    *Mighty Max/Ram 50 2.0L truck motor mounts will allow the 4g63 to bolt right into the trucks, but you will need to do some beating and/or cutting of the firewall to make room for the thermostat and cam angle sensor on the back of the head. If you don't want to mess with the firewall you will need to make/modify the stock mounts to move the motor forward about 2" to make room, but then you will also need to modify the transmission crossmember and lengthen the driveshaft to accommodate the 2" the power train moved forward. If you don't want to do that you can get a water housing outlet relocation kit(Jay Racing makes a commonly used one) to mount it to the front of the engine but there is additional modifications required. Check out the projectzerog.com forums to find more info on what needs to be done to do this.
    *Water pump: You will probably want to use the 2.0L truck water pump so that you can easily route the hose from your radiator to the water pump. Doing this requires some grinding of the ribs on the outside of the water pump to make clearance for the 4g63's timing tensioner parts. You need to have the 4g63's water pump pulley pressed flatter to align it with the alternator and crank pulley. For the water pipe coming out of the back of the water pump you will have to weld on barbs/fittings for hoses to be connected to for the turbo,oil filter housing, and throttle body water lines
    Pic of truck water pump clearanced for tensioner parts:
    *Intake manifold: You will need to cut off or make a new flange to be welded onto the front side of the intake manifold for the throttle body and make a plate for the old spot.
    Pic to show intake manifold. You don't need to add the extension, it just made it easier for my setup:
    *Turbo: The turbo needs to be rotated 180* on the exh. manifold to route the exhaust out to the back and the intake to the front of the vehicle. You will also need to reclock the turbo center housing so the oil drain points straight down and you can also reclock the front compressor cover to point the compressor outlet any which way you need it. New oil drain and feed lines will need to be made and also new water lines. You will need to buy an o2 housing flange and make a new exhaust down pipe for the turbo.
    *Thermostat housing cover: You can run the thermostat housing cover from a Mitsu with the 1.8L(4g37) motor. It will point the outlet away from the firewall like the stock 4g63 cover and towards the side of the motor for easier hose routing.
    1.8L bottom 4g63 top.
    If you have any questions or even more info just post and I'll add it into the thread.
    Info from AaronB31 on 7-Bolt swapping
    Quote Originally Posted by AaronB31
    - For starters, if it's in your budget, I agree with everyone who says you should go 6-bolt. The only reason I went 7-bolt was because I was on a budget and got a steal on everything I needed out of a 7-bolt dsm. I plan on building a 6-bolt to drop in and make some bigger power later on, which should be real easy as all the work is already done.
    - Neither the 2.0 truck water pump nor the 1.8 thermostat housing will fit the 7-bolt motor.
    - I was able to use the 2.0 trans, starion (225mm) clutch, and dsm pressure plate. However, one of the biggest obstacles I hit (and no one else doing this swap seems to have run into this problem) was that throwout bearing wasn't reaching the clutch. I had to take the bearing apart and add some length to it to get the setup to work properly.
    - The 2.4 motor mounts work perfectly with very little modification to the mounts. Even the thread patterns are the same for the bolts. However, if you chose to save money and time by not moving them forward (and keeping the transmission where it is with stock drive shaft usable), you will need to chop a huge hole in the firewall to make it fit. Make it bigger than you think it needs to be, because you're going to be reaching back there quite a bit when you get to plumbing coolant lines and whatnot. I then welded a new section of firewall further back, worked out pretty well.
    - I bought 2 gates 22436 water hoses online ($15 each) and they worked perfectly for upper and lower radiator hoses with no modification. It's challenging to find a hose that works and fits around the turbo, so I thought this was worth mentioning.
    WA
    Just opened this sticky. Lol. To add, the Mitsubishi starion and conquest clutch disc fits nicely in the oem dsm flywheel and pressure plate. It's just weird to have to buy the dsm pressure plate and still required to buy the starion/conquest clutch kit for the pilot bearing and throw out bearing, and alignment tool to just toss the brand new unusable starion/conquest pressure plate.
    The 2g dsm mounts differently to the engine bay then the 1g dsm mounts. The 1g has 3 motor mounts and one transmission mount opposed to the 2g dsm has 1 engine mount and 3 mounts that bolt to the trans. The 2g dsm motor does not have the bolt holes that are for one of the motor mounts required to mount to the truck motor mounts. An adapter plate must be made.
    I have run the engine harness uncut meaning no wires shortened or extended from the 90 harness, bu this makes it look messy as the wire harness goes over the engine between the number 3 and 4 spark plug wires the way I routed from the firewall. Also I did the lazy way and left the factory truck harness in the truck instead of removing it. More work you put into the swap, the cleaner it will look.
    Unmentioned is the throttle cable. The oem carbed throttle cable can be used but it's a bit long. You can be creative and shorten the cable, but the extra cable does no harm as it sits on the valve cover. You can be creative on the throttle cable bracket, my personal one is from a chrome spark plug wire holder that I bought from napa that holds two wires and bent it 90° and bolted it to the 10mm bolt provision closest to the throttle body. This allows for adjustment still.
    I tried using a starion clutch disc the firat time i swapped the 4g and it didnt work for me. The pressure plate was hitting/rubbing the disc and not allowing it to engage the clutch all the way. Went back tostock truck disc and no problems, besides a little slipping sometimes.
    WA
    Weird that it didn't work for you. I'm using a Sachs starion disk in the dsm fwd flywheel. Oem quality, and I don't feel much slipping other then the tires.
    KKaneohe,aneohe, hawaii
    Does anyone know where I can get a complete motor swap. Only thing is I live in Hawaii. Help would be greatly appreciated. Thanks.
    milford pa
    I see u say the 2.0 stock moumts work but what abiut 2.6 motor mounts? Are they the same?
    Just an FYI,, I just found out today in Screwed up California, you can't swap out a car engine into a truck. The referee says that the state has determined the emissions will be heaver since the truck is built to haul things. So it is a no go with the state. But you can swap in a truck engine into a truck. I know, I know, it makes no sense at all but that is what they told me.
    OH and if you do a swap they must be able to plug in and commentate with the PCM or you fail. The PCM must also have the proper Vin information in it to match the paperwork you bring in. So now the PCM must match the engine.
    1993 Mitsubishi Mighty Max
    Well, that sucks. I thought I was going to get around that by just doing the head change, but I would still need to change the ECU.
    I guess that explains why the ECU's are always pulled out of the cars in the junk yards here.
    I guess that saves me a bunch of money.
    I knew daredevils and I ain't got nothin' against them, ........it's just they're all dead.
    When in doubt call the smog referee. They are there to answer your questions.
    lethbridge,AB
    1983 Dodge Ram 50
    4G63
    Does anyone know if 2.0 first generation ram 50s mounts will work for 4g63?
    Mount Images
    Orlando, FL
    G64B
    Just to clear up some info on this thread you can use a 7 bolt 4g63 with a might max motor mounts, here is my conquest with 7 bolt motor and motor mounts from a 88 mighty max 2.0
    What year is that 7 bolt 4g63? all the ones I have seen are with exhaust on drivers side and intake on pass side
    Orlando, FL
    G64B
    from 93 up 4g63 were 7 bolt
    Orlando, FL
    G64B
    93-99 eclipse, 93-98 galant, had the 7 bolt with the exhaust on the passenger side
    Ok thanks I must have been looking at the wrong 4g63s then
    In the pictures above did you mod the intake? i know in Cali they won't allow it to pass. Ask DroppedMitsu. He will confirm that.
    Orlando, FL
    G64B
    I just moved the throttle body to the other side of the plenum, so it would face the front of the car and not the rear
    thats the same mod starquest owners do to aussie magna intakes to swap the throttle body location.
    NY
    anyone selling a swapped mighty max I am looking for one to buy
    Salem Oregon
    Was the narrow block transmission ever available 4wd? I've been thinking about doing this engine in my first gen 2.6 4wd.
    Not that I know of, but not really a 4x4 guy. Maybe some one else will know and chime in
    Maybe this will help,
    Mobile, AL
    Just tryin the market out. I'm an ls guru. I own a 95 mighty max. Was wonderin if the 2.4l is junk or if it can be built up. Interested in a dohc swap wondering how hard is it to do so I can keep the factory Trans in the truck now which is a 5 speed.
    It can be built, although you do have a 7 bolt motor... the earlier 6 bolt motor is preferred. There is no aftermarket support.
