Results 1 to 8 of 8
Thread: After market rims
    Kevil ky
    After market rims
    Does anyone know of a place or website that has aftermarket rims for a 88 ram 50? I know it’s 6 lug but unsure of the pattern also I’m going for kind of a drift truck style type rim nothing off road in the driver Side door frame it calls for a 14” rim I currently have 15” rims what will it hurt to go a bigger size then suggested? Also I’m new so helloo
    Owensboro, KY
    4D56-T
    6 lug GM pickups and really any Japanese 6-lug trucks have the same pattern. Should be a 6x155 if memory serves.
    It won't hurt to go up to maybe a +3 size (17") as long as you don't go crazy with rim width. Low profile tires are the first stop to improved handling and grip. Getting some offset will help avoid the inside edge of the rim fouling the upper front control arms but then you will need to factor in it either possibly fouling the fenders or the dreaded bump steer (a steering damper/stabiliser will help to tone that down).
    Nevada
    Im trying to find some 18" wheels that dont look hideous, so i can mount them on my 4x4 Max. So far its been a struggle.
    Indianapolis, IN
    I have 16 inch procomp steel wheels and 31 inch Mickey thompsons with 1/4 inch spacers it sits nice
    bolt pattern is 6 x 5.5 (139.7 mm) with a 108 MM center hole - the center hole is critical for the rim to fit flat on the hubs.
    Champaign, IL
    That looks great! My 4x4 truck needs tires, and I'm looking for some 16x7 aluminium wheels to potentially go up a size or two.
    Cant Say
    Dodge V6
    if its a 2wd it needs to have a 93mm center hole
