If thats the case ill pair it to a earlier model 727 and call it a day. The mm already has the shift mechanism and kickdown linkages set up. if you ran a carbed setup with a 750 then itll be even easier. Just have to put a regulator from the fuel pump. I know mopar makes a kit to convert the engine to carbed. Idk how they do ignition system
