Results 1 to 13 of 13
Thread: Ram 50 will turn over but will not start
    Anderson sc
    1986 Dodge D-50
    Ok I'm getting a ram 50 4x4 from a friend of mine and the story was they took it to the auto auction and somebody messed with something and tried to low ball them. They had driven the truck to the auction. So what can be done that quick that can be undone and it run? I'm buyin the truck either way because I'm gettin it cheap and worse case I can swap the motor
    KY
    G54B-T
    check to see if the distributor rotor is missing or if the coil is disconnected.
    Anderson sc
    1986 Dodge D-50
    Just by chance what is the firing order on these?
    charleston ar
    you may want to make sure its timed correctly also.
    Anderson sc
    1986 Dodge D-50
    Ok how do I do that?
    charleston ar
    make sure that the #1 piston is tdc on the compression stroke, then you take the distributor cap off and it should be pointed at the #1 coil.
    Anderson sc
    1986 Dodge D-50
    Ok that's simple enough I'm ready to get to work on this thing just got o get it to my house now
    Vacaville CA
    check the plugs and distro cap, timing helps as well but it should not be a issue if the drove it to auction. the distributor cap is on the rh side of the engine just before the carb..... check that it is tight and then pull it off and check the rotor cap make sure its there. after that check all the wires and firing sequence. If it is just backfiring chances are the wires were swaped.
    Adairsville ga
    1986 Dodge D-50
    I'm having this same problem and my timing is correct but I'm not getting any crank...I changed the oil pump and water pump and all was good before then as far as the motor starting.. Any suggestions I've been on this thing for 3 days
    union sc
    4G52
    i have an 1987 2.0 drove came back cut it off and now will turn over but will not start
    union sc
    4G52
    has new fuel pump new ignition coil spark plugs wires distributor cap rotor button and is in time and also has fire and good compression
    If you have spark, check fuel next. If you can get it to cough after manually priming the carb then you'll need to investigate the fuel system. If the fuel pump has been replaced check the orientation of the fuel lines. If the primary fuel line and the accelerator pump lines have been swapped it will either die off idle or not run at all. A faulty fuel cut solenoid on the carb will kill it as well. If you're not getting any fuel check that the pump is picking up. Does the new pump require a spacer? Is the actuator rod working? How are the fuel filter and lines looking? It'll be something small you've overlooked. Good luck with solving your issue, I doubt it's anything major.
