Results 1 to 4 of 4
Thread: Smokey and rough idle starts
    Eugene, OR
    1984 Dodge Ram 50
    4D55-T
    Hello,
    Just wondering if anyone had any ideas why my 84 TD with manual glow plugs white smokes for the first couple of minutes or so while warming up unless I juice the glow plugs. It will rough idle also unless I hit the glow plugs. Seems like once it comes up to a certain temp it goes away. Just wondering if anyone with a manual setup has the same problems or know what I should be checking? More air to the intake? maybe air in the fuel lines... thanks for any help.
    You should have a glow plug timer and temperature sensor on the engine. White smoke = not enough heat in the cylinders to burn the fuel. If you are running them manually then yes it will smoke, shake, and run rough. The timer and temperature sensor work together and keep the glow plugs at the correct temperature. This will keep white smoke down to a minimum. Then when the temperature is high enough the glow plugs will not come on at all.
    Eugene, OR
    1984 Dodge Ram 50
    4D55-T
    Ok thanks for the info. Where are you putting the temp sensor and timer? And where can I find these parts? I guess that you are wireing the temp sensor to the timer?
    Thanks again
    look in the manual section. Under 216 manuals. In there is a Haynes manual that covers the montero and the pick up trucks. I think it has a wiring diagram that will show where they are located in the system. The temp sensor should be near the T, stat.
