Page 2 of 5 FirstFirst 1234 ... LastLast
Results 26 to 50 of 109
Thread: Latrine
  1. #26
    Lawton, OK
    1980 Dodge Ram 50
    Chevy V8
    Yes there is. Its on the passenger side of the engine. 4G52
  2. #27
    Portland, OR
    I'll be damned...a chain timed even exhaust 2.0l. Thought that valve cover looked odd, but just put it up to it being older.
    If yer not going to use that engine...I think I see mechanical rockers on that thing (picture kinda small, hard to tell..)? I'd buy em off ya in a heartbeat if they are indeed mechanical. If ya are, just feel free to ignore me!
  3. #28
    4g52 is a chain cam 2.0 from 79-82 available in 4spd (wide) and auto (Narrow) versions in base trucks. 2.6 auto blocks were also narrow block bolt pattern till 87 - be careful if you go to swap motors - 12.5 is narrow block , 13.25 is wide block, measured across the 2 lower bolt holes center to center. That truck being a sport should have a 2.6 in it.
  4. #29
    Lawton, OK
    1980 Dodge Ram 50
    Chevy V8
    Yes its stamped on the block. 4G52
  5. #30
    Lawton, OK
    1980 Dodge Ram 50
    Chevy V8
    Idk why i just posted that...lol.
  6. #31
    Lawton, OK
    1980 Dodge Ram 50
    Chevy V8
    Engine numbers are
    G52B
    52F26248
    Could sombody look it up and tell me exactly what motor it is and where it came from please.
  7. #32
    Look 3 posts up at Pennyman's post.
    Josh
    09 BMW 335i E92 Twin turbo
  8. #33
    Quote Originally Posted by DOPRIUS View Post
    Engine numbers are
    G52B
    52F26248
    Go into the manual section. Look for the first gen factory manual. In there is a vin# decode page.
  9. #34
    Lawton, OK
    1980 Dodge Ram 50
    Chevy V8
    Its not the factory motor that came with the truck. It has been swapped, so has the trans.
  10. #35
    Lawton, OK
    1980 Dodge Ram 50
    Chevy V8
    Ok well I ran into a roadblock while dissasembling the head...its no good. Looks like my big plans of swapping to a 4.8 Vortec will comence.
  12. #37
    Lawton, OK
    1980 Dodge Ram 50
    Chevy V8
    Well luck isnt on my side (story of my life)...my car has cracked the flywheel FOR THE 3RD TIME...so Im about to aquire a Vortec 350 with 4L60e transmission behind it, to get the little D50 running for a daily. YUP
  13. #38
    Sorry about the car but looking forward to seeing the v8 build thread.
    Josh
  14. #39
    Lawton, OK
    1980 Dodge Ram 50
    Chevy V8
    Thanks. Yea Ive seen V8 dakotas with the little chrisler V8s that are fast. But they wont be anything compared to this truck when I put the motor in. It WILL be a sleeper...it WILL need drag radials haha
  15. #40
    No you won't need drag radials you'll need a truck to "drag" the broken "chevy" home
  16. #41
    Lawton, OK
    1980 Dodge Ram 50
    Chevy V8
    Yes you will need drag radials you'll also need a truck to "drag" the broken "ford" that you just raced, home
    IKR thats what im sayin haha
  17. #42
    Lawton, OK
    1980 Dodge Ram 50
    Chevy V8
    This is my inspiration for the D50. The guy has less than 4,000 in the car and it runs 9s.
    http://www.youtube.com/watch?v=_TWX8EZD2ek
  18. #43
    Lawton, OK
    1980 Dodge Ram 50
    Chevy V8
    This is my quick rendering of what i want it to look like.
  19. #44
    Buckingham,VA
    4G67
    What no paint or bodywork,? just drop it and ride
  20. #45
    Lawton, OK
    1980 Dodge Ram 50
    Chevy V8
    Well you gotta realize i did all of this with paint! LOL no fancy photo shop or anything like that. If you look at the other picture of it on my thread you can see that i did do some body work to it.
  21. #46
    Lawton, OK
    1980 Dodge Ram 50
    Chevy V8
    Ment toupload this one
  22. #47
    Buckingham,VA
    4G67
    Do you know how to make a Ford run faster ?? Put a Chevy motor in it
  23. #48
    Lawton, OK
    1980 Dodge Ram 50
    Chevy V8
    Quote Originally Posted by 92bluemax View Post
    Never fails!
  24. #49
    Buckingham,VA
    4G67
    I was defending you from the comment in # 40
  25. #50
    Lawton, OK
    1980 Dodge Ram 50
    Chevy V8
    The turbos i will be using (GT35s)
    The tranny (th400 with high pressure valve body)
    The engine (fully stock 4.8 Vortec)
