Results 1 to 9 of 9
Thread: Frame build opinions
    Tucson, Az
    1987 Dodge D-50
    So I junked a 88 mm but the frame with notches I kept. I also have a 87 d50 with 2.6 5 speed motor being built right now. So I'm looking at building the frame I kept and once built take everything from the 87 and swap to built frame. What does everyone think? What issues do you think I will have? Btw I will get pics tomorrow.
    It should bolt right on.
    Tucson, Az
    1987 Dodge D-50
    I'm not to worried bout that camoit. I've just noticed things like wiring and brake lines I think will be my worst obstacles. I'm looking more towards what people think bout building a frame for another truck.
    Tucson, Az
    1987 Dodge D-50
    Here is the frame I'm gonna build and the 88 d50 that will be getting frame someday.
    If they are the same wheelbase, they should interchange without problems. Since both are carb motor frames, the fuel lines and such are also the same. The only difference I could see causing a problem is if the one truck was a standard cab long bed and the other was an extended cab short bed - the wheelbase is the same, but the bed and body mounts would be in different places.
    Tucson, Az
    1987 Dodge D-50
    Has anyone ever cut the bottom off the engine crossmember and welded a plate or is a Z pretty standard to lay frame?
    Yes people have done it and it is perfectly fine to do it that way. Much easier than a z imo.
    Josh
    09 BMW 335i E92 Twin turbo
    Tucson, Az
    1987 Dodge D-50
    Anyone have any pics of cutting engine crossmember and welding a plate?
    augusta ga
    Quote Originally Posted by Uneek98 View Post
    thats what i did. only problem is steering arm hits about 1/8 inch before frame lays. but nothing that will hurt anything and eventually drag off, plenty of metal is left and wont affect steering. much less work than zing. but dont be afraid to z the frame if you have some fabrication experience its not hard really
