You need to find a different inspection / emissions place if they told you that. The only reason they should look is if the truck fails emissions. There is a new law for emissions - 85 and older no longer need emissions, with pre 96 in the works. PA found out that pre 96 cars are not worth the cost to run emissions, and they are usually collector cars that see little road time.
