sounds like the brake pedal adjustment or the booster rod adjustment. It might be holding the pressure in the system. Otherwise the calipers are sticking and not sliding correctly in the bracket. Remove the caliper and wire brush the parts where they should slide. File down any burs. Check pedal free play.
