Results 1 to 5 of 5
Thread: oil pan gasket suggestions
    Fresno CA
    just rebuilt my 88 mm 2.0
    1. Bought a fel-pro oil pan gasket from autozone for $10. It leaked as I'm getting the timing straight. I thought I might have not put it on correctly.
    2. So I bought another fel-pro for $10 from autozone. Put it on today and tightened the bolts. As I was doing that, the piece of SH&* cracked as pressure was applied on the bolts.
    So does anyone have any suggestions for a higher quality oil pan gasket other than POS paper fel-pro? I just want to get this mm running without an oil leak from the pan gasket!
    Black Silicone........... Screw the gasket. It will never leek again.
    Jacksonville, FL
    G54B-T
    Yeah, silicone gasket maker/ rtv/ silicone.....whatever you wanna call it. I like a product called "right stuff" . Its in a pressurized can with a nozzle that you tilt and it comes out. Just gotta make sure the surafces are nice and clean.
    WA
    I used permatex ultra gray. One and only gasket from felpro I don't trust is their oil pan gasket.
    Stafford, VA
    Chevy V8
    ive never had problems with them ...i have ruined one by not following the correct sequence of the bolts when tightening ....
