Results 1 to 6 of 6
Thread: mystery brake booster line?
    swansea, il
    1991 Mitsubishi Mighty Max
    Have this "T" fitting plummed into my brake booster hose the small line running off just has a screw jammed into it to plug it. I've looked in the general area to see ifit had a home and can''t find anything. The vac line sticker under the hood and looking through the chiltons manual I don't see anything it could go to. is this another previous owner mystery job??
    Jacksonville, FL
    G54B-T
    Id say thats something added by a previous owner
    I would remove the current hose and put a new one piece hose in its place.
    swansea, il
    yeah I just pulled the T and there was enough slack left in the hose to make it to the nipple.
    Between this and the mystery harness in the same area I almost wonder if it wasn't for a aftermarket cruise control setup at some point. who knows?? Always fun trying to unf*ck someones elses handywork.
    Could have been, but you should never cut the vacuum line to the booster for anything.
    swansea, il
    tell that to the PO. lol
