Results 1 to 9 of 9
Thread: lug patern???
    london, KY
    lug patern???
    hey gotta quick Question for trying to find the lug pattern for 89 ram 50 2wd ext cab 6 lug
    i found some 17" rims from a 2011 silverado 1500 6 lug they only have 8,000 miles on them and hes only wantin 500 for them i think they are 6x5.5 wonderin if they might fit any body know??
    Our trucks are 6x5.5, so yes they will fit. You will need to bore the centers of the rims out or grind down the tabs on the hubs thouh.
    Alabama
    1991 Mitsubishi Mighty Max
    4G52
    Quote Originally Posted by baker4401 View Post
    NO,not without modifications to the center bore and the backspacing might be wrong
    You will need buldged lugnuts as the silverado has 14 mm lugnuts and the 12 mm lugnuts on our trucks will barely contact the wheel.
    Jacksonville, FL
    G54B-T
    I have 2005 silverado 17 inch rims on my truck. They had the center hole bored out by the previous owner. The centercaps are held on with plastic lug nut covers that screw onto threads on the outside of the lug nuts. In order to use the factory lug nuts I bought threaded inserts from a company named "wurth" that makes "time-sert". We usually use them to fix stripped spark plug holes. I cant recall the part # of the ones I used. Basically a sleeve thats threaded on the inside and outside. Screwed them into the chevy lugs with loc-tite to make a 14mm lug fit a 12mm stud.
    Columbus, OH
    Reference material for all.
    Wheel Bolt Pattern Cross Reference Database
    http://www.roadkillcustoms.com/hot-r...e-Database.asp
    Lawton, OK
    1980 Dodge Ram 50
    Chevy V8
    What about a '80 model D50? They 6x5.5?
    Yup all Mighty Max/D50 are 6x5.5.
    Lawton, OK
    1980 Dodge Ram 50
    Chevy V8
    Thats a whole lota sweetness! B)
