Results 1 to 7 of 7
Thread: Just got an 89' Mitsubishi Mighty Max in CA
    California
    Its the 2.6L model. It only has 40,000 original miles and I got it for $2000. Its probably going to need new tires soon because it was sitting for a while and the tires are old. I think it has some sort of vacuum leak at the brake booster because it bogs as you press the brakes and sometimes stalls when coming to a stop.
    If it sat for a long time the diaphram in the booster might have cracked. easy enough fix. you can get one from www.rockauto.com for around $90
    And welcome to the site
    Portland, OR
    40k miles? WOW! Damn good score.
    If it's been sitting for a long time, make sure no mice made nests out of your wiring, too. Or bees nests in the ducts, etc, etc.
    Welcome aboard!
    Jacksonville, FL
    G54B-T
    pics!!!
    California
    The haynes manual says not to take apart the brake booster because it requires extra tools. How do I actually replace the booster diaphragm. I remove the booster and take it apart? Also, does carb cleaner hurt the rubber hoses and stuff so I can search for a vacuum leak? I will try to get pics soon.
    You just replace the hole thing. Unbolt the master and pull the 4 nuts in the cab. Forget trying to just replace the diaphragm.
    Jacksonville, FL
    G54B-T
    carb clean isnt good for the hoses but it should be okay unless theyre already in sad shape.
