Results 1 to 5 of 5
Thread: 4wd shift?
    Sidon,ms
    4wd shift?
    When I shift from 4wd to 2wd I have to pull forward and backward to make it unlock .
    Is that normal for this truck?
    zzion
    I think this is normal. If you look in the manual section you can find the owners manual. Page 30 is the start of the 4WD info.
    most older 4x4's you had to do that with.
    Tucson, Az
    1987 Dodge D-50
    Even with the newer trucks its always a good idea to go a bit in reverse and then drive
    Payette, ID
    yup, flip down your visor it will tell you how do do it. Yeah you must back up about 5 ft in 2wd for the front hubs to unlock, if you back up in 4wd they will unlock and then lock in again.
    1987 2WD Mitsubishi Mighty (R.I.P)
    1984 4WD Toyota Pickup (Sold 10/12)(Rolled and Totaled 3/24/13)
    1987 4WD Power Ram 50 Custom (Scrapped)
    1991 2WD Ram 50 (Scrapped)
    1992 Ford F250 7.3 (sold)
    1999 GMC Yukon (DD)
    1988 Ram 50(project)
