Results 1 to 7 of 7
Thread: Timing question
    Chesapeake, VA
    Timing question
    My truck is back up and running but the timing is excessively retarded no power and rough idle. I was going to adjust it but someone told me i could take the plug wires off the cap and move them all over by one. I just wanted to know if this would work and which way i would rotate them 1-4 or 1-2 thanks. Also i dont mind if it makes the timing slightly advanced
    If it's running then that will not work. It only has a range of movement. To advance the dist you turn it in the "Opposite" direction of rotor rotation. If that is not enough then you need to pull the dist and advance it by 1 tooth and re-time. If you look at the cap and the firing order of the wires then you would turn the dist in the opposite direction. I want to say the direction of advance is counter clockwise. OR the direction of the vacuum advance will pull.
    CA
    1983 Dodge Ram 50
    it could also be that you have a vacuum leak and your distributor isnt getting proper vacuum at RPM. Ive also seen the vacuum motor on the distributor go bad before too.
    Quote Originally Posted by OutcastZeroOne View Post
    OR the line is hooked up incorrectly to the wrong place.
    Chesapeake, VA
    i just had to move the distributor over a notch =) SHES ALIVE AND WELL AGAIN
    Wasn't that hard, was it.
    Chesapeake, VA
    it twas cake work mmmmm cake
