I have a 88 ram 50 2.6l mikuni feedback carb. I put a new head on. I rigged up a funnel so i could load the carb with fuel.
no matter what I do the pump wont prime. There is plenty of fuel in the tank the pump was working fine before the head work. The hoses were put back on the only way they will fit. When I prime the carb the engine will run perfect for a half minute then stall. I've loaded it several times the pump will not prime. What do I do now?
Thanks
Zion
