Results 1 to 3 of 3
Thread: ECTA Wilmington, Ohio July 7th & 8th Landspeed Racing
    Well I had some problems.
    Pulled the Turbo and Exhaust Manifold, #2 doesn't look good.
    I had done a Leak-down test and was pushing coolant out the top of the rediator.
    Pulled the Head, and found this!
    #2 &#3 got steam cleaned. you can see the head gasket leakage to the 3 closest coolant passages
    No water in the oil though. caught it before it got horrible.
    Convenient storage space while waiting on the new Head Gasket.
    full series here http://mmeierle.com/2012%20Racing.htm
    So how much do you need to weigh in your class? Do you need to have a full metal bed? Or can you lighten it up. You can pull the inner walls and remove 8+ Lbs
    Weight is actually a good thing in LSR, it's not so much about acceleration, and at bonneville you need the traction. At Bonneville, a lot of guys used lead pigs to add weight, even the bikers lead fill the swingarms.
