Results 1 to 4 of 4
Thread: Electri cooling fan conversion
    Sidon,ms
    I ned a electric cooling fan bad. I have the old clutch fan. I found aftermarket fans on ebay. How do I connect it? Where do I get a thermal switch to make it work?
    Thanks zion
    Just check out Summit racing
    http://www.summitracing.com/search/D...t/?Ns=Rank|Asc
    Fan controllers.
    http://www.summitracing.com/search/D...n/?Ns=Rank|Asc
    14" or better fan that moves 1500+ cfm
    The negative gets grounded to the body and the positive gets hooked to the controller positive. just follow the instructions that come with the controller and its easy. the other way to do it is get a relay and hook it to an ignition positive , but doing it that way the fan is always on when the truck it turned on.
    Sidon,ms
    I've found a relay switch that will screw into the block and switch the fan on.
    Is there a place on the 2.6l block where it will screw in?
    Thanks
    zion
    Sutherlin, OR
    I got a 12" from autozone and bought a 3 way switch and fused it. Don't remember how I set it up though
