Results 1 to 2 of 2
Thread: Mitsubishi 2.6l g54b head
    Sidon,ms
    Cool Mitsubishi 2.6l g54b head
    Hi And thanks for your support.
    I have a ram 50 with a 2.6l g54b jet valve head. I've got to replace the Hgasket but I've got to get a better head.
    I've heard mention that certain other heads "2.0l- 2.2l- 2.4l" can be used to improve power and performance. Anyone know what specific heads will work on this block?
    Thanks Again.
    It is a g52b for a 78-82 2.0 astron motor - it will raise the compression with a smaller combustion chamber but may not fit on 2.6 motors after 1984 due to changes in the configuration of the ports between block and head. The post 83-89 g63b 2.0 or 89 up 4g64 2.4 heads will not fit the 2.6 as they are a different engine series. There are several sellers with non jet valve heads out there that a machine shop can port for you, or you can port them yourself if you are up to it.
