Results 1 to 10 of 10
Thread: bucket seats
    Chesapeake, VA
    bucket seats
    what kind of bucket seats would just bolt up to my existing bench seat holes 91 MM
    Tulsa, OK
    The only ones I've ever known to bolt right on are Dodge D50 bucket seats...if you can find them.
    Phoenix, AZ
    I have a 90 MM extended cab and the late 90's-early 2000 Nissan Altima seats bolted up perfectly on the outside holes and I was able to weld some square tube the the Nissan rails and the inside rail bolted up. Maybe a maximum of an hour of work per side.
    My Dad put Eclipse seats in without much work.
    Chesterton, IN
    1991 Mitsubishi Mighty Max
    jbrockman...snap a pic of the seats in your ride will ya?
    Tulsa, OK
    Quote Originally Posted by jbrockman View Post
    Pics pics pics pics pics!!!
    Jacksonville, FL
    G54B-T
    I used a pair of starion / conquest buckets. They don't come close to bolting right in. No matter though since im so short that they wouldn't sit up high enough anyway. I used some 2 inch square tubing welded to the floor to bolt it down and raise it up.
    Chesapeake, VA
    ah im about 6'6 -.- and sadly also i dont have a welder at my house ill have to see if i can borrow one or go to my aunts shop and use hers
    Tulsa, OK
    Does anyone know if the Chevy S10 60/40 Buckets Seat would fit? I'm not too worried about a direct bolt on, more worried if I can shut the doors or not.
    I believe it was too wide when I measured my cousin's sonoma a while back, i could be mistaken on that though.
    Tulsa, OK
    I was afraid of that. I guess I'm going to have to come up with something else.
