Its not there for cooling but for cold startup. It raises the idle on startup becausr there is a spring with a end that partially blocks an air port and when the coolant warms the spring contracts and opens the air port and the idle lowers. I know on my 2.0 turbo 4g63t you can get rid of the FIAV(fast idle air valve) because it unscrews from the throttle body and can be blocked, but i cant tell from the pic if you're able to do that on your throttle body.
It also stops freezing of the throttle body. At the right temperature it will freeze behind the throttle plate and get covered with ice.
