Results 1 to 7 of 7
Thread: Rewire
    Hilo hawaii
    1989 Dodge D-50
    Rewire
    Got a 89 ram50 for free the truck needs to b completely rewired? How much would it COST to have a professional do it it's 2.0liter manual,carburetor????
    Tucson, Az
    1987 Dodge D-50
    If you put a weber carb on you will cut out about 50% of the wiring, It will allow you to delete the ecu.
    Why does it need a rewire?? If it needs to be done you're probably looking at 10-20hrs depending on what needs to be repaired or replaced and how far the truck needs to be striped to get axcess to the broken wires.
    If it needs to be rewired you will want to do it your self. A shop will charge by the hour.. There is no real estimate on any electrical job.
    Hilo hawaii
    1989 Dodge D-50
    The cab and bed are off of the truck the cab is fully stripped there's nothing in it the engine is still attach to the frame as well as the suspension I wanna give the truck a paint job in and out but if rewirering is gonna b to much or to hard ill have to get rid of it I have no idea how to do it.i got the truck for free I figured I put a little money into it then I got me a nice daily driver.
    You can always get one of these http://www.summitracing.com/parts/PRF-30001/ they come in 12 or 18 fuse blocks. the real nice thing about them is everything is marked so all you have to do is run your own wires.
    Buhl, ID
    1989 Dodge Power Ram 50
    G64B
    If you find the same truck in a junk yard, pull the wiring harness out of it and put it in yours. Easy to do and will only take a couple of hours.
