Results 1 to 19 of 19
Thread: New guy with a 4d55. Need a cylinder head!
    Hagerstown, MD
    1985 Dodge D-50
    4D56
    Hi guys, vanderchevy recommended this site so i went ahead and signed up.
    I have a 85 ranger with the 4d55, the head gasket blew so i pulled the head to discover that it is toast, cracked very badly out from the precups and cracked between all the cylinders so i need a new head. From my research it looks like i 4D56 head is a bolt on replacement and nice upgrade. Does anyone on here have a head for sale or know of a good place to buy one? Ive found a few on ebay but im not sure of the quality........
    Also any tips you have of things i should do while the head is off would be great! I turned the pump up already and im looking for a little more power but not going all out as i have a duramax with over 500 hp and a thousand foot pounds of tourque for that .
    TIA
    Welcome to the site and congrats on the truck. There are quite a few mitsu diesel gurus on here, I'm sure they'll be on to help you out asap. Enjoy the site, lots of cool features and info on here, especially if you become a donator.
    Hagerstown, MD
    1985 Dodge D-50
    4D56
    Thanks for all the help!
    The diesel guys arent on here all the time so it might take a few days, but dont make posts like that or you might not get any help. But if you do a search youll find what your looking for as I know ive seen that question asked a bunch and answered a bunch of times.
    KY
    1996 Mitsubishi Montero
    4D56-T
    Hagerstown, MD
    1985 Dodge D-50
    4D56
    I did search and the only thing i found was a recommendation on where to buy heads (head-r-us on ebay), i am planning on buying a 4d56 head but was hoping someone that new if it would work or not would chime in.
    KY
    4D56-T
    The 4D56 head will bolt on to the 4D55.
    send off a PM to 4d55preformance and ask him for his advice.
    Hagerstown, MD
    1985 Dodge D-50
    4D56
    http://www.ebay.co.uk/itm/4D56-T-2-5...ht_1281wt_1185
    How does this head look? Seems to be what i need and is from headsrus. Did you guys call to order it for the discount or buy online?
    Laporte, IN
    1989 Dodge Power Ram 50
    your gonna be hard pressed to find a used 4d56 head in the USA. your going to have to look overseas like that ebay post.... unless you know someone who is willing to find parts and ship them over to you. while your head is off you need to look at those cyl walls..... i bet you they will have a big step in them. due to the ring design the compression adds force to they rings. good luck.
    Hagerstown, MD
    1985 Dodge D-50
    4D56
    I found a complete new 4d55 head in florida on ebay Gonna buy it because its cheaper. You are right about the step at the top of the bore, does that mean it needs a rebuild?
    Hagerstown, MD
    1985 Dodge D-50
    4D56
    bump......
    Benton, Ks
    1984 Dodge D-50
    Yeah. More than likely.
    Nevada, Iowa
    1983 Dodge D-50
    Quote Originally Posted by Bustedknuckles View Post
    TIA
    Would you like to sell your old head? I need the pre combustion chambers for a 4D55 head.
    Hagerstown, MD
    1985 Dodge D-50
    4D56
    Quote Originally Posted by PARTSLINGER View Post
    Yea, how much you give me for it?
    For a good line on parts call these guys. If they can't get it, then you are going to need to scrounge the flebay.
    http://brheadblock.com/
    Nevada, Iowa
    1983 Dodge D-50
    50.00 sound fair?
    Laporte, IN
    most likely you are going to have to have the block either re sleeved or bored and locate some over sized pistons. but you first need to check the bore size and condition to see where to go from there.if you need it sleeved thats pretty easy since they are a dry sleeve and it is not Lipped.........
    Burbank, CA
    1983 Mitsubishi Mighty Max
    4D55-T
    The ebay heads are safe to use I have installed a handful over the last year. Also buy complete with roller rockers because they are quieter and don't flatten the cams like the originals do!
