Results 1 to 5 of 5
Thread: Need a measurment if anyone can help.
    Chesterton, IN
    1991 Mitsubishi Mighty Max
    im starting the rear of the truck, got the bed off and took measurments...my rear axle is 1 inch off on the pass side from the driver side.... I measured from the rear of the frame to center of axle, from rear cab mount to center of axle, from cab rear to center, all are 1 inch exactly different....not sure which one to use???? anyone have any info on the frame specs? or if anyone can putt a rear frame to axle measurment...
    Manual section. first gen. full frame and body measurements. I don't think they got any longer over the years. 112 inch wheelbase.
    If you can use a frame hole near the front. Measure in an X pattern.
    Chesterton, IN
    105.1 wheel base. on 2nd gen....the frame is fine, the axle isnt right..no big deal i guess, ill just use the longer number since the axle will pull forward when laying low..
    Jacksonville, FL
    G54B-T
    im thinking the one leaf spring is sagging and thats why the measurement is off 1 inch......just guessing though
    Chesterton, IN
    ya i dont have too many leafs in there..lol..i set it at the bigger number so when laid out it will pull forward some.
