Thanks guys, I will check out the manuals section. I'm not a forum noob, but will admit I didn't do any browsing before posting up, just searched in the areas I was interested in at the time.
I am in the process of selling my house and moving into another at the same time (bigger garage, lol) and will wait until then to pull the motor. Think it will be easier on me with more room.
Which of the above do you think i should do right off the bat? I'm gonna do air/fuel filters, plugs/wires/cap/rotor, and A/C parts first. Then pull motor down the road and clean/paint it and replace all gaskets and seals and timing belts and tensioners and things like that. Will surely adjust valves and do valve seals while I'm in there.
Is there any need to go ahead and rebuild while it's mostly apart, or should I just not worry about it? It runs great, but smokes a little white on startup and burns oil from cam/crank seals.
Thanks again guys.
