Page 2 of 4 FirstFirst 1234 LastLast
Results 26 to 50 of 91
Thread: they said a girl cant do it...93 Mighty max body dropped and bagged build up
  1. #26
    South Hill, WA
    1993 Mitsubishi Mighty Max
    <<<<< EDIT >>>>>
    You Must be a DONATOR to sell parts on the site.
    Please refer to this post for more information.
    http://www.mightyram50.net/vbulletin...ming-a-donator
  2. #27
    South Hill, WA
    Here is some pics of the setup in the rear with the 4 link together
  3. #28
    Savannah, GA
    Running the exhaust through the cross member like that is awesome, great work! Those are nice wheels too I have one of them on my isuzu.
  4. #29
    Chesterton, IN
    1991 Mitsubishi Mighty Max
    is your muffler under the cab? or ya going without? Mine is under the bed but i think im moving it to the cab underside...this looks great..keep going..
  5. #30
    South Hill, WA
    Payrion: We want it to be as quite as possible in the cab so at this point I am unsure where its going..I think it going in the rear =)
    LethalEthan: Thanks it took a while to drill threw the steel and we friedone of my drills .. smoking and everything lol..
  6. #31
    the muffler will be fine either way as long as the exhaust dumps outside the body not under the a floor. My first build I just dumped the exhaust after the muffler and at 60-70mph in OD the thing droned like a Mo-Fo under the bed so bad I had to take it out of OD after 10 minutes of driving.My current build the exhaust will dump out the sides of the box just in front of the rear wheels.The mufflers are under the cab floor and are Dynomax Ultra flows and all I hear is the exhaust at the tips.
  7. #32
    People-banned-for-one-reason-or-another
    Donations-Made-and-what-you-get-by-becoming-a-donator
  8. #33
    Savannah, GA
    Yep, i've burned up a drill like that before. Frames dont like it when you try to put holes in them.
  9. #34
    South Hill, WA
    Yeh no kidding Lethal =) Tomorrow I am off to replace my mans drill..
  10. #35
    South Hill, WA
    Thanks for the information camoit =)
  11. #36
    South Hill, WA
    Ohhhh yeah... DROP SPINDLES are HERE =) Time to put those bad boys in
  12. #37
    British Columbia, Canada
    1986 Dodge D-50
    Wow those wheels are REALLY nice! This truck is going to be so boss, can't wait to see the drop spindles on! Great, great stuff!
    -RHP
  13. #38
    Quote Originally Posted by LoBeauty View Post
    Don't take it personal.
    Donators are like drug dealers. They made the rule, then paid off the cops. You can always join them. We have several ways.
    The best is to Upgrade your account by becoming a donator and receive a free Decal.
    With all donations of $15.00 you will receive a Small Decal.
    For a Donation of $25.00 and up you receive a Large Decal.
    http://www.mightyram50.net/vbulletin...ightyRam50-net
    We are all waiting for Scarlett to be fitted with one of the 2 he received.
  14. #39
    Jacksonville, FL
    G54B-T
    Yeah ..,my exhaust exits under the bed instead of out from underneath the truck. It gets a ill annoying. Its actually louder riding in the cab then if u stood next to it.
  15. #40
    NC
    Workin on a body drop right now myself and tryin to decide were to cut on the fire wall at. What made you choose were you did? Had you seen someone else do it right there? Is there ganna be a space issue with the brake booster? Your interior is great for your first time!!! Project is lookin good to. For my tranny cross member I cut the nuts of the back and used a 1/8" or 3/16 in plate with bolts weled flush then just welded 1 1/2' square to it and used stock mounting bracket, then just tighten the nuts down on top of mounts almost like stock but not welded on. Good luck, and keep up the good thjread!
  16. #41
    South Hill, WA
    The firewall was planned by staring at it for about an hour or so and figured the cuts we made were the best spot for when the cab fell the sheetmetal would line up the best. As for the steering and brake booster part buy cutting it where we did the booster stayed in the same location as did the steering box hole. Also kept the gas pedal mounts and almost everything important on the drivers side stayed where it needed. However with z'ing the frame for the engine craddle the steering box hole will have to move up the amount of the z but I'll still have space between that and the brake booster. Thats a good idea for the trans member but sense I have to drop the motor the reverse about of the z for the stock hood clearance I'm just gonna fab up an entirely new trans crossmember. I already have the steel for it in the garage.
  17. #42
    South Hill, WA
    Here is more pics of progress
    The frame is 12" from the ground and can fit a 27" tire
  18. #43
    That was how it was in the camo truck. The best description I can give you is that it's just like flying in a Cessna.
  19. #44
    South Hill, WA
    What is the easiest way off dropping or lowering the engine a 1.5"? Also what is the easiest way to z the frame an all this with the body still on the frame and the engine in place? Should we just pull the motor and tranny to do all this? Does anyone have a picture or a link thread that could help?
  20. #45
    Jacksonville, FL
    G54B-T
    minitruckin magazine did a mighty max project truck..... i dont think a girl did it.......but im not gonna say a girl cant do it...; lol
  21. #46
    NC
    I've z mine and have pics but I need a minute to find what file/location there in to share. Yes pull the motor and trany. By z-ing it u raise the motor and can cut the motor mounts off and lower them. I'm lowering mine bout 5/8 but also notched and reinforced the crossmeber. Here is my custom compared to stock.
  22. #47
    You could always use spacers between the trany X member and frame. Some DOM tubing and longer bolts.
  23. #48
    South Hill, WA
    Alright more work has been completed =) Enjoy!
    Pulled out the motor and tranny for zing the frame
    Nice and clean now =)
    Tank, compressors and valves mounted
    Sealed the cab except for the steering column
  24. #49
    South Hill, WA
    Well the rear suspension is done we aired it up for the first time yesterday evening.. 4 link, caliper and brackets, drums, and drop spindles came back from from powder doating they look amazing =) Here is some pics !!
    Ill post more later as well =)
  25. #50
    South Hill, WA
