1 Attachment(s)
Seatbelt Recall for Mitsubishi Trucks - Have Yours Been Replaced?
Those of you that have just purchased your first Mitsubishi / Dodge truck need to research the federal recall listing on these vehicles. If you have never had it checked for this recall, then you truly need to find out if your truck falls into this requirement. The seatbelts are a must and especially in a collision.
Good ole Mitsubishi cut some corners in the safety department and installed some self destructing seatbelt buckles in our trucks. They were nabbed by the feds and required to have these replaced with new ones. Though I am pretty sure they slap the same crappy ones in, but newer.
Anyway, this is a free repair for your truck and you should get it checked to see if they have been replaced. Recalls done to our trucks usually end up with a recall sticker placed under the hood with a recall number identifying it to the owner. If you find out your truck has not been repaired, contact the nearest dealer to have the repair completed. It's better to know it has been done then finding out later when they are peeling your face off the front windshield.
Here is the information for the recall.
Attachment 12149
Recall 95V103004
For Models: Mitsubishi 3000GT, Mitsubishi Eclipse, Mitsubishi Mighty Max, Mitsubishi Mirage, Mitsubishi Montero
Body, Interior & Misc., November 1, 1995
Summary: THE FRONT SAFETY BELT BUCKLE RELEASE BUTTONS CAN BREAK. THESE RED PLASTIC RELEASE BUTTONS ARE MARKED "PRESS." IF A BUTTON BREAKS, PIECES CAN FALL INTO THE BUCKLE ASSEMBLY CAUSING THE BUCKLE TO OPERATE IMPROPERLY.
Original Recall from the NHTSA
Manufacturer's Report Date: November 1, 1995
NHTSA CAMPAIGN ID Number: 95V103004
NHTSA Action Number: PE94093
Component: SEAT BELTS:FRONT:BUCKLE ASSEMBLY
Potential Number of Units Affected: 658000
Consequence: THE SAFETY BELTS WOULD NOT PROVIDE ADEQUATE PROTECTION TO AN OCCUPANT IN A VEHICLE CRASH.
Remedy: OWNERS SHOULD PROMPTLY CHECK THE CONDITION AND OPERATION OF BOTH FRONT SAFETY BELT BUCKLES AND CAREFULLY INSPECT THE RED RELEASE BUTTON FOR ANY BREAKS OR CRACKS. THEY SHOULD ENSURE THAT BOTH BUCKLES ARE OPERATING PROPERLY BY INSERTING EACH LATCH PLATE INTO ITS BUCKLE, TUGGING ON THE BELT TO MAKE SURE THE LATCH IS SECURELY LOCKED, AND THEN PRESSING THE RELEASE BUTTON. THE LATCH PLATE SHOULD POP OUT OF THE BUCKLE WHEN THE BUTTON IS PRESSED. IF EITHER RELEASE BUTTON SHOWS A SIGN OF BREAKING OR CRACKING OR IF EITHER BUCKLE FAILS TO OPERATE PROPERLY, OWNERS SHOULD PROMPTLY CONTACT THEIR AUTHORIZED DEALER TO SCHEDULE AN APPOINTMENT TO HAVE THE BUCKLE REPLACED OR REPAIRED, FREE OF CHARGE. THE MANUFACTURER IS DEVELOPING A REMEDY DESIGNED TO PREVENT FAILURE OF THE BUTTONS THAT ARE NOT CURRENTLY BROKEN.
Notes: SYSTEM: INTERIOR; SEAT BELTS; BELT BUCKLES.VEHICLE DESCRIPTION: PASSENGER VEHICLES AND LIGHT DUTY TRUCKS AND VANS EQUIPPED WITH SAFETY BELTS MADE BY TAKATA CORPORATION.NOTE: IF YOUR VEHICLE IS PRESENTED TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND THE REMEDY IS NOT PROVIDED FREE OF CHARGE WITHIN A REASONABLE TIME, PLEASE CONTACT MITSUBISHI AT 1-800-222-0037. ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-800-424-9393.
