Hi Guys,
The manual lists torque specs for the:
Automatic Tensioner Bolt
and
Timing Belt Tensioner Bolt
Which is which?
Hi Guys,
and
Which is which?
I think you are confusing the Tensioner Spacer(which is a bolt) and the Tensioner Bolt (which set the tension on the timing belt)
page 11-C35 actually check out the entire section.
http://mmeierle.com/images/Max/1G%20...2%20ENGINE.pdf
I assumed that one was the spacer and one was the bolt, but the manual doesn't provide a description of either. However, after looking at your doc, I see the spec for each. The spacer is 49ft and so is the bolt. But mine shows the Automatic Tensioner with a different value.
Automatic Tensioner Bolt 14-20
Timing Belt Tensioner Bolt 32-40
So I'm not sure what they are talking about. But yours sounds pretty good to me so that's what I will go with.
Also, your doc is for a 92, mine's an 88. Hopefully they're the same. :)
I just spotted the Auto Tensioner in your diagram.
I don't have one of those. :)
