Battery wires getting HOT!! / No instrument cluster lights
87 MM 4x4. The smaller set of wires on the pos batt side(not the large starter wire) are getting really hot along with the lil white block mounted next to the coil. I started having problems when I removed my instrument cluster. Im particular about my work and careful not to pull pinch any wires. But my green instrument cluster lights are not working but everything else (seatbelt, egr, speedometer is working and other warning lights etc.) are. So I'm left with a very hot +batt small wire leads and lil white box beside the coil and the inside instrument cluster . Not sure not sure what's going on but if anybody out there can steer me in the right direction be greatly appreciated I'm a little bit better at mechanical side butt the electrical I have a lot to learn. Thanks
