In line lift pump?
Hey y’all,
1984 mighty max 2.3 4d55t
I’m new to the forum, but I’ve been lurking here trying to gather info for awhile. I’ve been trying to diagnose a fuel starvation issue, or that’s what I think it is anyway. The truck would run decent for different periods of time, 20-45 minutes, then would begin to sputter and die out. I recently replaced the fuel tank because there was loads of rust and gunk built up inside of it. That seemed to help a bit, but I still get starvation issues under WOT in third which will cause the truck to die after 3-4 seconds of WOT. I was debating putting an in line transfer pump from the tank to the filter housing. I wanted to ask the greater knowledge base here for advice and direction. Thanks in advance!
I run a 60 gph electric pump between the fuel tank and the fuel filter. Haven't had a single problem with that setup
Awesome thanks for the reassurance, I’ll be ordering a pump today!
